aaaah ... success !
Fred /
In the last week my newfound speed seemed to dwindle mysteriously away. (Honda PA50I)
The symptoms ?
Just gets to 25mph.. and kinda bogs there and 'crackles'... it won't rev out... (the same way it acts till it warms up)
Following all the typical advice I give people... I did a fairly quick carb clean... found no dirt or blockages... hmmmm why is it slow then ?
Cleaned the points.
Checked ignition timing... it has moved since I last set it... so I re-set it about 5 times.. till it ended up where it should (a little advanced).... hmmmm .. no help ... why is it slow then?
Checked the air filter... not bad... it still acts lean anyway... dirt would richen it up.. experimented with removing the air filter.. no help... taped the filter up (to reduce air flow)... no help... dang !
This time I cleaned the carb very carefully.... NO HELP !
Awright... slept on it... and I just had the feeling that something ws just stopping the airflow.
The exhaust pipe is a handmade one... several years old... nearly straight thru (except for the easily removed baffle I made for it).
I have never cleaned it because it is so simple.... I suspected maybe the only 'tight spot' in it might be carboned up.
I jammed a bent rod up there and wiggle-waggled it around... while I was at it I cleaned the exhaust port a little... (not bad).
WOOO-HOOO!
It flies now... that exhaust pipe must have slowly built a carbon brigde over that 'tight spot'.
It goes an easy 35mph on flat ground.
My 0-25 has dropped to 15.5 seconds... (was at 26... then 22... then 19... now 15.5)
If I had reached this point a week ago... I would have ridden to the BBQ (150 miles).
By the way... Chris R. - this is without the PA50II reed valve... when I get that and gear it up (IF I can)... this thing could do 50 maybe.
  aaaah ... success !Topic by: Fred Fred 05/26/02 10:21PM
  Re: aaaah ... success !Re: Matt Wilson Matt Wilson 05/26/02 10:43PM
  Re: aaaah ... success !Re: Matt Wilson Matt Wilson 05/26/02 10:52PM
  Re: aaaah ... success !Re: Fred Fred 05/26/02 11:07PM
  Re: aaaah ... success !Re: vapor vapor 05/27/02 12:31PM
  Re: aaaah ... success !Re: Fred Fred 05/27/02 01:42PM
  Re: aaaah ... success !Re: Fred Fred 05/27/02 01:51PM
  Re: aaaah ... success !Re: david f martin david f martin 05/26/02 11:06PM
  Re: aaaah ... success !Re: Matt Wilson Matt Wilson 05/27/02 01:20PM
  Re: aaaah ... success !Re: Fred Fred 05/27/02 01:45PM
  Re: aaaah ... success !Re: Matt Wilson Matt Wilson 05/27/02 01:56PM
  Re: aaaah ... success !Re: Fred Fred 05/27/02 02:08PM
  Re: aaaah ... success !Re: Matt Wilson Matt Wilson 05/28/02 01:40PM
  Re: aaaah ... success !Re: Fred Fred 05/28/02 02:43PM
  Re: aaaah ... success !Re: Matt Wilson Matt Wilson 05/28/02 06:56PM
  PipesRe: Fred Fred 05/28/02 07:52PM
