ok i pretty much figured mopeds are supposed to leak alittle, but like how much is alittle? my moped wpnt leak for days then all of a sudden gas will run and oil will leak, just making a mess.
Clean your float, it's probably sticking.
-R
whenever you are not riding it, turn your fuel valve to the off position.
Your moped shouldn't leak at all.
As Paul L said, if you can't fix your sticking float (or dirty needle valve) then use the ol' petcock to shut off the supply.
Chris.
