Re: go buy 4 new cylinder studs
Ron Brown /
Garret,
I am not sure what you did to your studs, but if you stripped the threads on the steel studs without stripping the aluminum crankcase, you are a better man than I.
Rimas' problem is that he has stripped the hole in the crankcase where the studs screw in. A helicoil allows you to tap the hole larger, then use the helicoil to reduce it to the original size. As a bonus, you now have a steel threaded hole which is unlikely to strip again.
Ron
  Now I've done it! DAMMIT!!Topic by: Rimas Rimas 05/25/02 03:24AM
  Re: Now I've done it! DAMMIT!!Re: Steve Steve 05/25/02 06:39AM
  Re: Now I've done it! DAMMIT!!Re: Rimas Rimas 05/25/02 01:37PM
  Re: Now I've done it! DAMMIT!!Re: Sebastian Sebastian 05/25/02 09:31AM
  Re: Now I've done it! DAMMIT!!Re: Rimas Rimas 05/25/02 01:38PM
  Re: Now I've done it! DAMMIT!!Re: Ron Brown Ron Brown 05/25/02 11:12AM
  Re: Now I've done it! DAMMIT!!Re: InfectedBootSector InfectedBootSector 05/25/02 01:05PM
  Re: Now I've done it! DAMMIT!!Re: Rimas Rimas 05/25/02 01:40PM
  Re: Now I've done it! DAMMIT!!Re: Ron Brown Ron Brown 05/25/02 01:54PM
  Re: Now I've done it! DAMMIT!!Re: Rimas Rimas 05/25/02 02:02PM
  Re: Now I've done it! DAMMIT!!Re: Ron Brown Ron Brown 05/25/02 02:14PM
  Re: Now I've done it! DAMMIT!!Re: Rimas Rimas 05/25/02 02:17PM
  Re: Now I've done it! DAMMIT!!Re: david f martin david f martin 05/25/02 10:50PM
  go buy 4 new cylinder studsRe: Garret Garret 05/25/02 11:17PM
  Re: go buy 4 new cylinder studsRe: Ron Brown Ron Brown 05/26/02 01:42PM
