go buy 4 new cylinder studs
Garret /
go2 mopedwarehouse.com. and order 4 new cylinder head studs, they have them for the Maxi's engine, i dunno about others. i did the same thing on my Tomos, and just replaced the studs. once you have the piston/cylinder off put vise grips on the ends of the old studs and unscrew them, they unscrew from the crankcase, then just screw the new studs in where the old ones came out of, and put 2 of the cylinder head nuts on the end of each and lock them 2gether and tighten the top nut to tighten down the studs (remove them after you tighten each stud of course!). i would think this would be a lot easier and more reliable than having the threads on the exsisting studs re tapped or helicoiled.
-Garret
  Now I've done it! DAMMIT!!Topic by: Rimas Rimas 05/25/02 03:24AM
  Re: Now I've done it! DAMMIT!!Re: Steve Steve 05/25/02 06:39AM
  Re: Now I've done it! DAMMIT!!Re: Rimas Rimas 05/25/02 01:37PM
  Re: Now I've done it! DAMMIT!!Re: Sebastian Sebastian 05/25/02 09:31AM
  Re: Now I've done it! DAMMIT!!Re: Rimas Rimas 05/25/02 01:38PM
  Re: Now I've done it! DAMMIT!!Re: Ron Brown Ron Brown 05/25/02 11:12AM
  Re: Now I've done it! DAMMIT!!Re: InfectedBootSector InfectedBootSector 05/25/02 01:05PM
  Re: Now I've done it! DAMMIT!!Re: Rimas Rimas 05/25/02 01:40PM
  Re: Now I've done it! DAMMIT!!Re: Ron Brown Ron Brown 05/25/02 01:54PM
  Re: Now I've done it! DAMMIT!!Re: Rimas Rimas 05/25/02 02:02PM
  Re: Now I've done it! DAMMIT!!Re: Ron Brown Ron Brown 05/25/02 02:14PM
  Re: Now I've done it! DAMMIT!!Re: Rimas Rimas 05/25/02 02:17PM
  Re: Now I've done it! DAMMIT!!Re: david f martin david f martin 05/25/02 10:50PM
  go buy 4 new cylinder studsRe: Garret Garret 05/25/02 11:17PM
  Re: go buy 4 new cylinder studsRe: Ron Brown Ron Brown 05/26/02 01:42PM
