Re: Could also be
Toehead /
Mo need to buy a jet. take the top off the carb, and there should be a slide valve there, with a silver pin on the bottom. If there isn't, ignore my advice. Take out the silver pin. You will see notches at the top. There will be a c-clip in one of the slots. to lean the mixture, move the clip up a few slots. do a plug chop, and keep adjusting the mixture un till you get it right or run out of slots. (then it's time to buy a new jet.) To make the mixture rich, reverse my procedure. move the clip down.
  burning spark plugs?Topic by: troy troy 05/25/02 01:55AM
  Re: burning spark plugs?Re: Garret Garret 05/25/02 02:11AM
  Re: Could also beRe: Jim C. Jim C. 05/26/02 09:31PM
  Re: Could also beRe: Toehead Toehead 05/27/02 11:01PM
