what kind of oil do i use?
i have a 1979 tomos bullet and i drained the oil out of the bottom thing where the peddle goes and i dont know what kind or how much oil to put in??? im lost
Re: what kind of oil do i use?
Dave Gregory /
benny,
you need 2-stroke oil. is it oil-injected (is there a place for the oil to go....) or do u have to mix it. if its oil injected then just fill the tank for the oil. if u need to mix it then look under the gas cap and it should say a gasoline to oil mixture. such as 50/1 or 30/1. if you need more help dont hesitate 2 ask.
~dave~
Scott in WI /
The 1978 Owners manual says...For gear box use oil for automatic gearboxes,Mobile Oil Valvomatic type A Suffix A or any other multigrade oils SAE 10W-30.
I use a 10w30 in my 3 tomos
Scott
What is the best between 10W30 and DEXTRON3 TYPE F ???
I have a TOMOS TARGA LX 1999 motor A35.
A Targe should use Dextron ATF not F.
A Targa should use Dextron ATF not F.
Don't listen to dave, he misunderstood you!!!!
Listen to Scott, he's got the right answer Benny!
Dextron 3 it is good ?????
In the small tomos book they said ATF TYPE A ??????
Reeperette /
Tomos Bullet Manual calls for 220cc's of 10w30 Motor Oil.
Tomos Targa Manual calls for 220cc's of Dexron type III ATF.
Some prefer ATF, some prefer Motor Oil, regardless of model.
Use what works best for you.
-R
