Clutch Springs (Ron Fred)
Matt Wilson /
On my 99 Zuma (I know its not a moped casey) I've done a bunch of mods. I put on a higher compression engine, larger carb, better airbox, carbon fiber exhaust...ect
I found that my belt was slipping a lot until I got going about 25mph. Then the bike took off.
Recently I bought a stiffer clutch sping, and put it on. It made a big difference. The bike now does wheelies!
Would an even stronger spring give me better low end?
Can you put in too strong a clutch spring? Would it harm the bike or have other bad effects? Malossi makes 2 stiffer springs...would the stiffest have any bad effects?
Also there is a dead spot between 12mph and 24mph. It sounds like the engine slows down in this zone. Does this sound like I should lean out my needle setting?
I know this is a scooter question, but no one in the scooter forums could answer it.
Also FYI the Zuma has a pulley transmission system with a front pulley (variator) and a rear pulley (clutch).
Thanks
Matt
Re: Clutch Springs (Ron Fred)
david f martin /
What scooter forums do you look at?
david
Ron Brown /
Matt,
I have no idea why a new clutch spring would stop your belt from slipping, but if it works, why change it.
As for mid-range dead spot, you have the carb, raise the needle, test it, lower the needle, test again.
Ron
Matt Wilson /
David,
Yahoo groups has a lot of info about scooters.
yamaha_zuma@yahoogroups.com
twist and go@yahoogroups.com
Matt Wilson /
<)IMG src=http://www.rpi.edu/%7Ewilsom/DSC00009.jpg
This is what the transmission looks like. Does anyone know if there are bad effects of adding too stiff a clutch spring? (in the back under the rusty clutch bell)
Matt Wilson /
Damn
www.rpi.edu/~wilsom/DSC00009.jpg
What am i doing wrong??
Matt
