Re: Success!
Jon Dalton /
In my experience with pullers, if you need to put a pipe over it then you are at the point where the puller is going to break.
The flywheel shouldn't be this hard to get off. They are supposed to be held on snugly by the tapered fit to ensure that they are centered and won't wobble or come loose, but that is only frictional force of the two pieces being wedged together as the flywheel expands and the crankshaft compresses.
The problem with yours is that cold welding has happened at the molecular level between the aluminum flywheel and the steel crankshaft. Since they are both finely machined and pushed very close together, the steel atoms directly contact the aluminum atoms in enough places to set up metallic bonding, so in fact in a whole bunch of tiny little spaces, the crankshaft and the flywheel act like one piece of metal. Of course everyone knows you can't weld steel to aluminum, I just mean at tiny little points on the molecular level, they could never actually weld themselves together. This happens a lot with aluminum car rims on steel hubs. If you ever get it off, a light coat of anti-seize compound or oil or grease will prevent it from getting this way again.
Using a torch will work, as the flywheel is going to expand more than the shaft when heated, and greatly reduce the force needed to get the flywheel off. Just be really careful of the magneto coils inside. If you keep the torch aimed at the centre of the flywheel, and don't heat for too long, you should be ok. Don't give up if it doesn't work the first few times, keep trying and it should come off.
  1978 Peugeot 103 woesTopic by: Chris Robertson Chris Robertson 05/23/02 09:46PM
  Re: 1978 Peugeot 103 woesRe: duck duck 05/23/02 10:00PM
  Re: 1978 Peugeot 103 woesRe: Dan Dan 05/23/02 10:11PM
  Re: 1978 Peugeot 103 woesRe: Ron Brown Ron Brown 05/24/02 10:56AM
  Re: 1978 Peugeot 103 woesRe: Chris Robertson Chris Robertson 05/24/02 11:01PM
  Re: 1978 Peugeot 103 woesRe: Chris Robertson Chris Robertson 05/25/02 07:39PM
  Success!Re: Chris Robertson Chris Robertson 05/26/02 06:36PM
  removing the flywheelRe: Jon Dalton Jon Dalton 05/27/02 12:06PM
  Re: removing the flywheelRe: Chris Robertson Chris Robertson 05/27/02 12:24PM
  Re: removing the flywheelRe: Jon Dalton Jon Dalton 05/28/02 12:20PM
  Re: removing the flywheelRe: Chris Robertson Chris Robertson 05/28/02 12:31PM
  removing the flywheelRe: Jon Dalton Jon Dalton 05/27/02 12:23PM
  Re: Success!Re: Dan Dan 05/26/02 09:20PM
  Re: Success!Re: Chris Robertson Chris Robertson 05/27/02 10:01AM
  Re: Success!Re: Jon Dalton Jon Dalton 05/28/02 12:42PM
