removing the flywheel
Jon Dalton /
This method has never failed for me, it's even worked where I've broken the puller. You can take a coat hanger, bend small hooks on either end with pliers, bend the entire thing in half, and hook each end of it in either the holes in the flywheel if there are any, or the edge of it if there is a big enough space between it and the engine case. Now, support the moped with one foot and pull on the coat hanger while hitting the crankshaft end with a hammer. It's best to keep the nut on, but so that it's flush with the end of the crankshaft, to avoid mangling the threads. I used this on a Torrot engine, which I'm told is the same as a 103, with the same symptoms you're describing. Adjusting the stator plate did nothing for me. I'm pretty sure in my engine and possibly yours that it needs NEW points and condensor. There were a few engines that I fooled with engines for hours, thinking the points and condenser are fine because I cleaned them, but the new points were what they really needed.
  1978 Peugeot 103 woesTopic by: Chris Robertson Chris Robertson 05/23/02 09:46PM
  Re: 1978 Peugeot 103 woesRe: duck duck 05/23/02 10:00PM
  Re: 1978 Peugeot 103 woesRe: Dan Dan 05/23/02 10:11PM
  Re: 1978 Peugeot 103 woesRe: Ron Brown Ron Brown 05/24/02 10:56AM
  Re: 1978 Peugeot 103 woesRe: Chris Robertson Chris Robertson 05/24/02 11:01PM
  Re: 1978 Peugeot 103 woesRe: Chris Robertson Chris Robertson 05/25/02 07:39PM
  Success!Re: Chris Robertson Chris Robertson 05/26/02 06:36PM
  removing the flywheelRe: Jon Dalton Jon Dalton 05/27/02 12:06PM
  Re: removing the flywheelRe: Chris Robertson Chris Robertson 05/27/02 12:24PM
  Re: removing the flywheelRe: Jon Dalton Jon Dalton 05/28/02 12:20PM
  Re: removing the flywheelRe: Chris Robertson Chris Robertson 05/28/02 12:31PM
  removing the flywheelRe: Jon Dalton Jon Dalton 05/27/02 12:23PM
  Re: Success!Re: Dan Dan 05/26/02 09:20PM
  Re: Success!Re: Chris Robertson Chris Robertson 05/27/02 10:01AM
  Re: Success!Re: Jon Dalton Jon Dalton 05/28/02 12:42PM
