Re: Success!
Chris Robertson /
Hi Dan:
I'm in Ottawa, Ontario, Canada.
I considered making my own flywheel puller. The diameter looks to be about 14mm. What size die did you use?
I wish I had a welding rig... But I can probably borrow one.
Did pulling your flywheel take an incredible amount of effort? I'm serious when I say I couldn't tighten my balance puller any tighter with my 8" socket wrench (I had to put a pipe over the end of it) before the balance puller finally broke.
Judging by my service manual, my timing is definitely out of spec (1.5mm BTDC is about 10-20 degrees after the rubber grommet is).
Thanks,
Chris.
  1978 Peugeot 103 woesTopic by: Chris Robertson Chris Robertson 05/23/02 09:46PM
  Re: 1978 Peugeot 103 woesRe: duck duck 05/23/02 10:00PM
  Re: 1978 Peugeot 103 woesRe: Dan Dan 05/23/02 10:11PM
  Re: 1978 Peugeot 103 woesRe: Ron Brown Ron Brown 05/24/02 10:56AM
  Re: 1978 Peugeot 103 woesRe: Chris Robertson Chris Robertson 05/24/02 11:01PM
  Re: 1978 Peugeot 103 woesRe: Chris Robertson Chris Robertson 05/25/02 07:39PM
  Success!Re: Chris Robertson Chris Robertson 05/26/02 06:36PM
  removing the flywheelRe: Jon Dalton Jon Dalton 05/27/02 12:06PM
  Re: removing the flywheelRe: Chris Robertson Chris Robertson 05/27/02 12:24PM
  Re: removing the flywheelRe: Jon Dalton Jon Dalton 05/28/02 12:20PM
  Re: removing the flywheelRe: Chris Robertson Chris Robertson 05/28/02 12:31PM
  removing the flywheelRe: Jon Dalton Jon Dalton 05/27/02 12:23PM
  Re: Success!Re: Dan Dan 05/26/02 09:20PM
  Re: Success!Re: Chris Robertson Chris Robertson 05/27/02 10:01AM
  Re: Success!Re: Jon Dalton Jon Dalton 05/28/02 12:42PM
