Check my motor !!!!
Somebody see a motor like this before ?
This is my FLANDRIA MOTOR 1974, only 538 miles, i rebuilt all my moped and i remove all the rust inside the gas tank.
To adjust my idle speed, i need to play with the gas cable.!?
The screw you see on the side of the carb, is the JET...!?
The carb is a ENCARWI !
Sombody said to me this motor is the same of a italian moped ????
Re: Check my motor !!!!
Ron Brown /
Alain,
If the screw has a spring to keep it from turning, it is the idle adjustment. The tip of the screw is tapered and holds the slide.
Ron
No spring,
It's only the jet #55.
NO i know i need adjust by the cable
InfectedBootSector /
It looks Italian, especially when compared to a Benelli.
My Flandria come from BELGIUM, they stop the production in 1980.
