Re: Grande Pedal Problems
Jim C. /
Jon:
A book on bicycle repair from you library will show you how a cottered crank works.
The only diference here will be that instead of bearings, you have bushings as I described before.
Once you remove the padal arm and pull out the shaft with the sprocket, you will see haow simple the setup is.
Jim
