Grande Pedal Problems
Jonathan Wyatt /
Hey Jim thanks for responding. I'm not too familiar with a cottered crank. The pin that is screwed into the pedal cranks doesn't have a head (flat, phillips, hex) on it at all so how would I unscrew the pin? If cottered cranking removes it... how do I do that?
So the nylon bushings are inside the subframe? If I am able to get the cranks off and get inside the subframe, you think that replacing these would solve the wobbling?
Let me know what you think... especially about getting those pins out...
