Cold weather boredom is getting to me...
What is everyone's running bike to non-running bikes ratio?
RUNNING DIVIDED BY YOUR TOTAL = YOUR %
Mine is 91.67 percent. I predict the overall percentage will be lower.
so are you staying up 24 hours a day refilling the tanks when they run dry?
^^^WTF
10 out of 14 are running, and no, I don't run around filling up tanks 24 hours a day. I rotate my bikes, and I drain their tanks, when rotated out. I will only have gas in 3 bikes at a time, at most. (edited)
Idling on the stands like that isn't good for the bikes....jk, I'm at 40%, time to get cracking I suppose.
IDK exactly what you're getting at...but if you put it away running and drained the tank, then that is still a runner.
I just mean, what runs and rides vs. not.
Harvey = 71.4%
7 out of 9 of mine are runner/drivers.
> the
> ^^^WTF
> most.
They are only running when they are running Harvey
77.8%
We are holding at an 80% average so far.
3 out of 5
dayum rob,
i am sooo confoozed, i have three running bikes. 1 frame but i have three extra running motors, the frame needs a rear wheel bearing. so how do i express that as an equation or equivilent in a ratio?
slewfoot <=>/+ 100%
Dude, I can't help you count the total when they are apart like that. You are either three out of 3 or 3/4 here. (edited)
72.7%
Does bikes in boxes ie basket cases count as non runners or parts?
how about that rob? parts to bike ratios....
i ordered a rear hub bearing so 3/4. parts to bikes i think i am at 5 parts to 3 working parts on a bike
I counted the bikes I can jump on and ride, or loan out to people... 7 out of 9... I do although have all the parts and running engines to finish the last two.
so I stand still at 7 out of 9 runner/riders.
Well if it's a roller with a motor in it, or you took it apart in order to repair it, then it's a non-runner in my opinion. One of mine with it's engine in a bucket I've counted as a non-runner.
No mopeds currently (I thought I swore off them), but I was talking to some one a few minutes ago that has a non running 1980 Red Vespa Bravo.
Vespa, Puch and Honda ... hard to resist the call of the moped.
I was finally at 5/5 and then my bravo subframe broke at the pedal shaft.
So now I'm at 80%. Boohoo
About 50%. Not bad since I have bought all of two bikes that were running in the first place.
with fresh gas and maybe a few carb cleans and i'm at 12 of 13.
once it warms and i bolt the engine the other i'll have them all road worthy.
20% :/
Buuuuut it's winter...
50% / 50%
-200%
3/5
Honestly 25%
Now, 90% running.
100% if you don't count an elite 250
0% right now
6/6, 100%. they all run, but 2 arent quite reliable yet.
A couple of you have brought the average down pretty far.
