RE: targa ignition?
Jon /
Sounds to me like a clogged filter. I bet right now the reason you ped will not run is your plug is once again fouled. If you were to replace it would run great for another two weeks, but replacing it would not solve the problem. You see when you have a cloged air filter it acts like a choke and sucks in alot of gas which would explane why it is running so good, but it is also fouls the plug due to the exess of carbon caused by all the oil being consumed. As a fix you should clean or replace the element in you air box depending if the element is rusted or not.
  targa ignition?Topic by: mike mike 10/11/00 03:49PM
  RE: targa ignition?Re: Jon Jon 10/12/00 12:17AM
  RE: targa ignition?Re: mike mike 10/12/00 03:34PM
  RE: targa ignition?Re: Fred Fred 10/12/00 06:08PM
  RE: targa ignition?Re: Jon Jon 10/12/00 08:33PM
  RE: targa ignition?Re: mike mike 10/12/00 08:45PM
  RE: targa ignition?Re: Jon Jon 10/12/00 10:51PM
  RE: targa ignition?Re: Reeperette Reeperette 10/13/00 10:22AM
