What is the setting of the idle screw supposed to be on a Tomos? I just got a used Tomos and need to know the setting to get this little guy running.
Thanks for your help.
Kevin Harrell
Kevin Harrell
It should start and run pretty much wherever its set at. Idle screw is only for your idle when the bike is stopped. I dont know much about Tomos but any other ped it has nothing to do w/ the bike running.
I have gotten a motocane moped that I'm try to get started.It looks to be a 1980 from pics I've seen at this site.Can you tell me the fuel ratio mixture.Thanks...Larry
If you buy the fancy expensive synthetic ?... use 50 to 1
(I don'y use it... its not worth it in my opinion)
(50 to 1 is 2.65 ounces of oil per 1 gallon of gas)
If you use regular 2 stroke oil... mix it at 3 ounces of gas to 1 gallon of gas (43 to 1)
