Idle screw adjustment
What is the setting of the idle screw supposed to be on a Tomos? I just got a used Tomos and need to know the setting to get this little guy running.
Thanks for your help.
Kevin Harrell
Re: Idle screw adjustment
It should start and run pretty much wherever its set at. Idle screw is only for your idle when the bike is stopped. I dont know much about Tomos but any other ped it has nothing to do w/ the bike running.
Larry garrison /
I have gotten a motocane moped that I'm try to get started.It looks to be a 1980 from pics I've seen at this site.Can you tell me the fuel ratio mixture.Thanks...Larry
If you buy the fancy expensive synthetic ?... use 50 to 1
(I don'y use it... its not worth it in my opinion)
(50 to 1 is 2.65 ounces of oil per 1 gallon of gas)
If you use regular 2 stroke oil... mix it at 3 ounces of gas to 1 gallon of gas (43 to 1)
