Re: ???
Ron Brown /
Jim,
Dwell is an over rated spec. It was usefull on old multi cylinder engines because it allowed you to average the point gap to compensate for worn distributors.
If you conside the length of time the points are closed at 1000 rpm and 5000 rpm, small changes in dwell pale by comparison.
Having said that, the relationship between the energizer coil, the flywheel magnet and the points opening, is designed into the magneto and if you change the timing too much, you will loose spark energy.
I guess if I were to do it, I would compare spark before and after.
Ron
  Grande..Widening the Points for more powerTopic by: Chris Rice Chris Rice 05/20/02 09:33AM
  Re: Grande..Widening the Points for more powerRe: Ron Brown Ron Brown 05/20/02 11:49AM
  Re: Grande..Widening the Points for more powerRe: Crisis Crisis 05/20/02 12:31PM
  Re: Grande..Widening the Points for more powerRe: Ron Brown Ron Brown 05/20/02 12:44PM
  Re: ???Re: Jim C. Jim C. 05/20/02 01:48PM
  Re: ???Re: Ron Brown Ron Brown 05/20/02 02:08PM
  Re: ???Re: Crisis Crisis 05/20/02 02:27PM
  Re: ???Re: Ron Brown Ron Brown 05/20/02 02:37PM
  Re: ???Re: Fred Fred 05/20/02 04:26PM
  Re: ???Re: Casey B Casey B 05/20/02 07:17PM
  Re: ???Re: Chris Rice Chris Rice 05/20/02 05:03PM
  Re: ???Re: Jim C. Jim C. 05/20/02 05:18PM
  Re: Grande..Widening the Points for more powerRe: Ken Ken 05/20/02 08:53PM
