Plug fouled ?
Fred /
My guess is you need a new spark plug.
(or you're starved for gas with a dirty carb or petcock)
get a new plug... if that doesn't help... try squirting a little gas into the carn intake... if it runs for a few minutes... then dies... you have to clean the petcock and carb and install an inline fuel filter.
Then do a plug chop.
If its brown (the plug)... try running without the air box or air filter for a short time to see if its better.
If you cleaned the points good once... you don't need to keep doing it... (though pulling a clean piece of paper through will let you know they are still clean).
Most mopeds have low miles on them... so they rarely need points.
  points cleanedTopic by: chad chad 05/19/02 03:45PM
  Plug fouled ?Re: Fred Fred 05/19/02 04:32PM
  Re: Plug fouled ?Re: chad chad 05/19/02 08:38PM
  Re: Plug fouled ?Re: Ron Brown Ron Brown 05/20/02 10:46AM
  Re: Plug fouled ?Re: chad chad 05/20/02 12:04PM
  Re: Plug fouled ?Re: Ron Brown Ron Brown 05/20/02 12:14PM
  Re: Plug fouled ?Re: Fred Fred 05/20/02 04:09PM
