Well after 2 hours of straight workin, I got the puch in running order. Starter Fluid started it up on the 2nd try. I ran it around the block but forgot to tighten the nut for the baffle, so that fell out and i had to find the bolt. I'm hearing a vibration comming from around the motor. I'm sorta thinkin that the new piston ring i ordered is too big, or i didn't tighten up a bolt enough.
