torch a tailgater
gimmyjimmy /
Shoot 20ft. flames out of your exhaust, here's how:
http://www.autoloc.com/detail.lasso?itemid=FLAME
Also would work on those pesky dogs that chase you...
turn them into crispy critters
but I'm not advocating turning pedders into pyros.
Re: torch a tailgater
na na na na na na na na
BATMAN!
Re: Model T coil
A Ford Model T ignition coil was the forst deice used to make one of these way back when.
Jim
Smoke and Fire
Does a moped put out enough unburned fuel to power one of those things? I'm also assuming you'd need an auxillary battery to power those coils.
If anyone does this... please let me know. I love this idea.
What would happen if you poured a bunch of oil into the exhaust by tipping the moped forward a little, and making sure a lot of oil drooled down to the hot spots near the manifold...--- as soon as you built up temp, would it begin to smoke like crazy?
Smokescreens and fire
heheheh
Settle down, Beavis
Re: Smoke and Fire
I think a moped would blow up if you shot flames out of the exhaust pipe.
Re: W4 Diddly
Some place I read about hooking up a system to dump WD-40 into the exhaust manifold on a car for a smoke screen.
That's another use not listed on the can.
As far as a Model T coil goes, they work from 3 to 28 volts, AC or DC.
Jim
