Re: Variator exploratory surgery
david f martin /
Another problem I saw with modifying the tracks (besides that it looks like an awful lot of work) is that if you don't get the stops exactly the same all the way around, it is gonna be off balance when the weights get there, with the crank turning full speed. An unbalanced spinning weight on the end of your crank is a quick way to wear out the crankshaft bearings.
david
