Re: Leaking Tomos Transmission
Miguel Centellas /
look over what everyone else posted. did you take of the transmission cover? if not, and it didn't leak before, start from there. if you took the cover off, and now it leaks, then you may have assembled it incorrectly. check the paper gasket and be sure all the seals are tight tight tight. you can replace the screw you mentioned easily enough, if you can get it to come out (i'm sure someone can give you directions on how to do that). good luck.
  crapTopic by: Nick Nick 05/15/02 03:49PM
  Re: crapRe: Ncik Ncik 05/16/02 06:39PM
  Re: crapRe: chris chris 05/16/02 06:58PM
  Re: crapRe: Simon King Simon King 05/17/02 02:32AM
  Re: crapRe: Chris Rice Chris Rice 05/17/02 09:43AM
  Re: crapRe: chris chris 05/17/02 09:58AM
  Re: crapRe: casey casey 05/18/02 08:07PM
  Re: crapRe: Ron Brown Ron Brown 05/17/02 12:26PM
  Leaking Tomos TransmissionRe: Wayne Wayne 05/17/02 09:43AM
  Re: Leaking Tomos TransmissionRe: Reeperette Reeperette 05/17/02 07:18PM
  Re: Leaking Tomos TransmissionRe: Nick Nick 05/18/02 03:16PM
  Re: Leaking Tomos TransmissionRe: Miguel Centellas Miguel Centellas 05/18/02 06:45PM
  UpdateRe: Nick Nick 05/19/02 11:22AM
  Re: crapRe: Nick Nick 05/20/02 07:35AM
