Re: Leaking Tomos Transmission
Reeperette /
First off, why were you removing that cover at all ? was it another problem ?
To fix the leak, you are probably going to have to get that cover off, somehow.
Now "stripped" ? do you mean the THREADS are stripped ?
Or did you run into those damn be-cursed no-account bastard Hex-head bolts ?
So, is the threads stripped, or just the top of the bolt ?
My reccommendation is to get that cover off even if you have to pay someone else to do it, then take one of those evil-damn-hex-heads to the local hardware store and have them give you FLAT HEAD machine bolts with the same thread and depth, so you don't have that problem any more.
Also it's likely that the paper gasket in there might be torn, or worn...so why not replace it while yer at it.
If the threads are stripped too, you'll have to re-tap and put a slightly larger bolt in there, is all.
And once you put it back together, fill it up with 220cc's of either Dexron III ATF (Targa) or 10w30 (Bullet), and there you go.
It really does help if I get a comprehensive description, and if you wanna guarantee I at least look at the thread, mention Tomos in the subject line.
Best of luck,
-Ree
  crapTopic by: Nick Nick 05/15/02 03:49PM
  Re: crapRe: Ncik Ncik 05/16/02 06:39PM
  Re: crapRe: chris chris 05/16/02 06:58PM
  Re: crapRe: Simon King Simon King 05/17/02 02:32AM
  Re: crapRe: Chris Rice Chris Rice 05/17/02 09:43AM
  Re: crapRe: chris chris 05/17/02 09:58AM
  Re: crapRe: casey casey 05/18/02 08:07PM
  Re: crapRe: Ron Brown Ron Brown 05/17/02 12:26PM
  Leaking Tomos TransmissionRe: Wayne Wayne 05/17/02 09:43AM
  Re: Leaking Tomos TransmissionRe: Reeperette Reeperette 05/17/02 07:18PM
  Re: Leaking Tomos TransmissionRe: Nick Nick 05/18/02 03:16PM
  Re: Leaking Tomos TransmissionRe: Miguel Centellas Miguel Centellas 05/18/02 06:45PM
  UpdateRe: Nick Nick 05/19/02 11:22AM
  Re: crapRe: Nick Nick 05/20/02 07:35AM
