i need some help on how to fix a motobecane. i need to know if there is any way tosee if the engine works without the spark plug wire? also, do i nee an air filter for a moped?
not sure what you mean. but you do need to have the spark plug attached to have the moped run. every time the piston takes a stroke the spark plug fires to ignite the gasoline/air mix. check out "www.howstuffworks.com" 's article on 2stroke engines for a better explanation. air filters aren't obligatory but it certainly doesn't hurt to have one.
dave
