horn no work
Capt. Walter /
I HAVE A 1978 PUCH MAXI LUXE THE HORN WORKS BUT WEAK, I REPLACED IT WITH ANOTHER STILL WEAK ,TOOK HORN SWITCH APART CLEANED IT STILL WEAK, THE BRAKE LIGHT WORKS BRIGHT BUT DOES NOT WORK WHEN I USE LEVER FOR REAR BREAK, THE TAIL LIGHT WORKS BUT WEAK,EVEN WHEN I REV UP ENG. I CHECKED BULBS THEY ARE O.K.
ANY IDEAS ON HOW TO MAKE HORN WORK RIGHT,AND TAIL LIGHT ???
THANK YOU
Re: horn no work
Dave Gregory /
hey walter
for the rear brake light you should reverse the polarity....it worked 4 me when i had that problem.
for the tail light is it a 2-filiment bulb??? if it isnt you should use one for it. is there a high-low light switch??? If there is you should clean it out and make sure all of the wires are connected correctly and in the right spot
~dave~
