Trying to replace a mirror
on a 2001 Kinetic TFR. The guy I bought it from has a small mirror that obviously doesn't go with the moped. I looked online for a replacement, but no luck. Any ideas where I can find one? I tried Treatland, but no luck. I've also been told that a Hobbit mirror might work. Anyone know if that's true? Thanks!
Re: Trying to replace a mirror
Andrew Squiggman /
treats has tons of mirrors. is your stalk 8mm or 10mm?
Jake LaMotta /
Treats has some that should fit. If they don't, figure out the threading size and get some motorcycle mirrors off of Ebay that screw into your brake levers. If you have a scrapyard near your house that has motorcycles you should be able to find some there too and they'll probably be cheaper than you can get them online.
Andrew Squiggman /
most motorcycle mirrors are 10mm. most moped perches are 8 mm
Jake LaMotta /
Ah, didn't know that. I had a pair of mirrors that either came off a dirtbike or motorcycle from the 80s that someone gave me on my TFR when I had it so I just assumed.
Jake LaMotta /
Regardless, here are a shit ton of 8mm mirrors on Ebay.
Tri-ped Dave O.D.B. /
or just perouse the Emgo catalouge. Most motorcycle dealers buy from them and can order you up anything in the book. They have dozens of styles that fit
This '80 Pooch end mount mirror...
THAT will be the second thing removed from this thing.
Why do I want to see where I just was?
yea take ur mirrors off rat...its cool...
to the o.p. you can even find heavier duty bicycle mirrors that are large enough fer a ped on ebay probably even from local bike shop...or post in buy/sell
Re: This '80 Pooch end mount mirror...
> thing.
You are not looking behind you to see where you just were, but for what is comming up behind you wanting to be where you are.
> buy/sell
The last thing I want is for my ped to look like yours. What the fuk happened?
they also make 10-8 mm adaptors to fit motorcycle mirrors to mopeds
Let him ride without mirrors. Maybe we'll be rid of him soon then.
^Good point Mars, between that and making zip guns the "Darwin rule" may well claim him sooner than later.
I have a pair of original ones, they're pretty much new, make me an offer.
