batavus help needed!!
i have a batavus with no spark! it ran a few months ago, according to a friend of mine. I dont think its the points, timing, or generator. what could it be? Should there be an ignition switch on this the handle bars, cause there isnt one!
RE: batavus help needed!!
there should be, see if the wires that led to it aren't grounding out somewhere.
did you try a new spark plug?
dan
Check the bobine and the sparkplugkabel.
language problem
Hey Ivo.... what else might a "bobine" be called?.... because that is one I've never heard of... what does it do?
RE: language problem
bobine is another word for an ignition coil (i think). I think its a really old term for a coil (bobbin --> bobine...coils are spun around bobbins..)
its nothing to do with the coil or points. The bike was running not 6 months ago. I think there is a loose connection or something on the body of the bike.
Not necessarily
Just because it was running 6 months ago doesn't mean it's not the points
It could be a fouled spark plug
It could be a clogged carb jet
It could be dirty points.
First you need to check for spark at the plug
Then you need to check that gas is getting to the carb
I wrote all this info in depth 2 months ago but I'm not writing it again till I figure how to cut and paste with this damn new computer!
