Re: noob intro, 1981 Yamaha Towny MJ50J
Todd Keingeshaft /
The Towny is a great noped, although its going to take some work to get it to to the speeds you have mentioned.
First off, as Full Tuck said, fix all of the problems with it first, and get it running well stock, before doing and mods to it.
Read this thread from start to finish...it will give you an idea of what you 'll need to do, and what your options are.
A Biturbo made for a Tomos A35 will also work, although not as well as the MLM, and sticks up in the air quite a bit. Seen in this thread
The CDI isn't limited, although you'd want one with a curve (Ignition retarded at higher RPMs) to keep the temps down. Although most of the first post is gone for some reason, here is a discussion about the stock CDI
CDI Thread. Best bet is a "scooter" CDI off of Ebay or something. Look for one made for a Yamaha Jog that has 3 single wires, and 2 that go into a plug. Its not "plug and play", but can be connected to the Towny wiring harness pretty easily.
If you are going to mod your Towny, do yourself a favor, and get a head temp gauge. They tend to run hot when operated above stock RPMs. I seized mine a couple times before finally getting one, and am glad I have one now as it has probably saved my engine more than once!
There is a lot of info on here about these, just search. Also search for threads on the QT50, as a lot of the information applies to the Towny, too. (edited)
  noob intro, 1981 Yamaha Towny MJ50JTopic by: edro . edro . 09/11/13 05:39PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: moped man moped man 09/11/13 05:41PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: matt boda1nz matt boda1nz 09/11/13 05:46PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: matt boda1nz matt boda1nz 09/11/13 05:50PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Probably Fred Probably Fred 09/11/13 06:25PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: edro . edro . 09/11/13 06:49PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: matt boda1nz matt boda1nz 09/11/13 06:54PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Probably Fred Probably Fred 09/11/13 07:13PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: edro . edro . 09/11/13 07:42PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Aldous Huxley Aldous Huxley 09/11/13 07:29PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Full Tuck Full Tuck 09/11/13 07:58PM
  1981 Yamaha Towny MJ50J =SCOOTERRe: fallout Survivor fallout Survivor 09/11/13 08:30PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Todd Keingeshaft Todd Keingeshaft 09/12/13 10:20AM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: kevin a kevin a 09/16/13 11:32PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Gary Herrisch Gary Herrisch 09/17/13 07:19AM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Full Tuck Full Tuck 09/17/13 09:38PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: edro . edro . 09/19/13 06:21PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: matt boda1nz matt boda1nz 09/19/13 06:47PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Todd Keingeshaft Todd Keingeshaft 09/19/13 07:44PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Gruff "(OFMC)" - Gruff "(OFMC)" - 09/19/13 09:57PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: edro . edro . 09/23/13 06:10PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Kiel the Canuck Kiel the Canuck 09/25/13 01:37AM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: bill Stoudt bill Stoudt 09/24/13 08:15PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Steve Gonzalez Steve Gonzalez 12/15/19 08:55PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Les B. Les B. 12/29/19 01:29PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Rob P Rob P 04/26/20 04:31PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Pushrod Fifty Pushrod Fifty 04/26/20 07:36PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Jack Rutherford Jack Rutherford 04/27/20 12:13AM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Pops Peds Pops Peds 04/27/20 09:17AM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Jack Rutherford Jack Rutherford 04/27/20 09:29PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: john cervini john cervini 04/27/20 10:54AM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Pops Peds Pops Peds 04/27/20 02:29PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: john cervini john cervini 04/27/20 03:55PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Pops Peds Pops Peds 04/27/20 08:02PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Kaleb Segelquist Kaleb Segelquist 05/01/20 08:01PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Joe K Joe K 10/11/20 05:38PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: live ɘvil live ɘvil 10/11/20 05:57PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Joe K Joe K 10/11/20 07:11PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Ron Peek Ron Peek 10/11/20 06:56PM
