Re: noob intro, 1981 Yamaha Towny MJ50J
Full Tuck /
love my towny, but it maxs out at 45mph due to ignition limitations.
0) fix yer current problems
1) drain and refill your transmission with SAE30 non detergent...i forget how much goes in there... 50ml maybe? 100ml?...ml==cc
2) drill a couple holes in the back of the airbox, this will get you up to 35mph (40mph downhill)
3) take off the rear fender and install a fatter rear tire to increase it overall diameter, this will get you another 1-2 mph
4) ride it and enjoy it. super peppy off the line
5) dont let it run out of oil
when you want to go faster...
1) you need to replace the carb, i put a 14mm PHVA on mine, took the intake to a machine shop and told them i wanted to spigot mount this carb to the stock intake
2) buy a QT50 mlm pipe and have it hacked, bent, and welded to fit.
remove the oil injection, it pumps so much oil that i was taking me like 10mins to get the engine up to running temps
want to go faster...?
1) figure out a way to make the ignition adjustable or hunt around n find a CDI that will work.
im not individually embedding these photos:
https://www.facebook.com/media/set/?set=a.10100518136861707.1073741825.33611777&type=3
  noob intro, 1981 Yamaha Towny MJ50JTopic by: edro . edro . 09/11/13 05:39PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: moped man moped man 09/11/13 05:41PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: matt boda1nz matt boda1nz 09/11/13 05:46PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: matt boda1nz matt boda1nz 09/11/13 05:50PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Probably Fred Probably Fred 09/11/13 06:25PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: edro . edro . 09/11/13 06:49PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: matt boda1nz matt boda1nz 09/11/13 06:54PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Probably Fred Probably Fred 09/11/13 07:13PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: edro . edro . 09/11/13 07:42PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Aldous Huxley Aldous Huxley 09/11/13 07:29PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Full Tuck Full Tuck 09/11/13 07:58PM
  1981 Yamaha Towny MJ50J =SCOOTERRe: fallout Survivor fallout Survivor 09/11/13 08:30PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Todd Keingeshaft Todd Keingeshaft 09/12/13 10:20AM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: kevin a kevin a 09/16/13 11:32PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Gary Herrisch Gary Herrisch 09/17/13 07:19AM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Full Tuck Full Tuck 09/17/13 09:38PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: edro . edro . 09/19/13 06:21PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: matt boda1nz matt boda1nz 09/19/13 06:47PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Todd Keingeshaft Todd Keingeshaft 09/19/13 07:44PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Gruff "(OFMC)" - Gruff "(OFMC)" - 09/19/13 09:57PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: edro . edro . 09/23/13 06:10PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Kiel the Canuck Kiel the Canuck 09/25/13 01:37AM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: bill Stoudt bill Stoudt 09/24/13 08:15PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Steve Gonzalez Steve Gonzalez 12/15/19 08:55PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Les B. Les B. 12/29/19 01:29PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Rob P Rob P 04/26/20 04:31PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Pushrod Fifty Pushrod Fifty 04/26/20 07:36PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Jack Rutherford Jack Rutherford 04/27/20 12:13AM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Pops Peds Pops Peds 04/27/20 09:17AM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Jack Rutherford Jack Rutherford 04/27/20 09:29PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: john cervini john cervini 04/27/20 10:54AM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Pops Peds Pops Peds 04/27/20 02:29PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: john cervini john cervini 04/27/20 03:55PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Pops Peds Pops Peds 04/27/20 08:02PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Kaleb Segelquist Kaleb Segelquist 05/01/20 08:01PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Joe K Joe K 10/11/20 05:38PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: live ɘvil live ɘvil 10/11/20 05:57PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Joe K Joe K 10/11/20 07:11PM
  Re: noob intro, 1981 Yamaha Towny MJ50JRe: Ron Peek Ron Peek 10/11/20 06:56PM
