Re: Poke it with a wire ?
jim /
I have used easy-off oven cleaner with very good luck.
It is a pretty common trick with ysr50 racers(stock class)
It may not unplug your exhaust but it will remove oil,soot,and
carbon from the inside of the pipe.
cap one end of pipe and spray entire can of oven cleaner into
pipe turn pipe to coat entire inside and let sit for a couple
hours,then hose it out.
good luck!
  unclogging the exhaust....Topic by: wrybread wrybread 05/11/02 02:53AM
  Re: unclogging the exhaust....Re: don-ohio don-ohio 05/11/02 02:59AM
  Re: unclogging the exhaust....Re: wrybread wrybread 05/11/02 03:04AM
  Re: unclogging the exhaust....Re: don-ohio don-ohio 05/11/02 03:23AM
  Re: unclogging the exhaust....Re: Chris Rice Chris Rice 05/11/02 03:36AM
  Re: unclogging the exhaust....Re: wrybread wrybread 05/11/02 07:19AM
  Re: unclogging the exhaust....Re: don-ohio don-ohio 05/11/02 07:42AM
  Re: unclogging the exhaust....Re: Casey B Casey B 05/11/02 02:47PM
  Poke it with a wire ?Re: Fred Fred 05/11/02 09:55AM
  Re: Poke it with a wire ?Re: wrybread wrybread 05/11/02 10:11AM
  Re: Poke it with a wire ?Re: david f martin david f martin 05/11/02 12:45PM
  Re: Poke it with a wire ?Re: Fred Fred 05/11/02 02:04PM
  Re: unclogging the exhaust....Re: david f martin david f martin 05/11/02 03:16PM
  Mangled it ?Re: Fred Fred 05/12/02 06:42PM
  freds advice site?Re: Ben Phillips Ben Phillips 05/12/02 11:38PM
  Re: freds advice site?Re: don-ohio don-ohio 05/12/02 11:39PM
  Re: freds advice site?Re: don-ohio don-ohio 05/12/02 11:42PM
  Re: freds advice site?Re: ben ben 05/15/02 12:18AM
  Re: freds advice site?Re: Fred Fred 05/15/02 12:54AM
  Re: Poke it with a wire ?Re: jim jim 05/12/02 05:07PM
  Re: Mangled it ?Re: david f martin david f martin 05/12/02 07:10PM
  Re: Hurt toesRe: Wayne Wayne 05/13/02 10:33AM
  Re: Mangled it ?Re: Chris Rice Chris Rice 05/13/02 10:53AM
  Re: Mangled it ?Re: david f martin david f martin 05/13/02 08:52PM
  Re: Mangled it ?Re: Wayne Wayne 05/13/02 10:29PM
  Re: Mangled it ?Re: david f martin david f martin 05/14/02 12:06AM
  David, VW QuestionRe: Ron Brown Ron Brown 05/14/02 11:46AM
  Re: David, VW QuestionRe: david f martin david f martin 05/14/02 08:20PM
  Re: David, VW QuestionRe: Ron Brown Ron Brown 05/16/02 01:36AM
