Poke it with a wire ?
Fred /
lol
Where do I say "poke it with a wire ?
I said... "attach it to a coathanger"... wire ... so you can place it in the fire and pull it out.
You aren't going to use your fingers I hope ?
To unclog it you need to get it real hot and burn it out... one way is to attach a coathanger wire to it and set it into the coals of a hot campfire... pull it out every 5 minutes or so to make sure it is not melting it... turning orange is OK... melting is not."
You set the MUFFLER in the fire... not just the coathanger.
You let it sit in there for a good while.... (if you have a true campfire with hot coals in it... it will only take 15 minutes in the coals... and pull it out once or twice to make sure its not melting.. the coathanger is there for you to pull it in and out)
And doesn't my instructionsa say to... "bang the ash out AFTER it cools" ?.... (as in -- don't bang on a red-hot piece of sheet metal... it will bend and deform like taffy).
Good luck.
  unclogging the exhaust....Topic by: wrybread wrybread 05/11/02 02:53AM
  Re: unclogging the exhaust....Re: don-ohio don-ohio 05/11/02 02:59AM
  Re: unclogging the exhaust....Re: wrybread wrybread 05/11/02 03:04AM
  Re: unclogging the exhaust....Re: don-ohio don-ohio 05/11/02 03:23AM
  Re: unclogging the exhaust....Re: Chris Rice Chris Rice 05/11/02 03:36AM
  Re: unclogging the exhaust....Re: wrybread wrybread 05/11/02 07:19AM
  Re: unclogging the exhaust....Re: don-ohio don-ohio 05/11/02 07:42AM
  Re: unclogging the exhaust....Re: Casey B Casey B 05/11/02 02:47PM
  Poke it with a wire ?Re: Fred Fred 05/11/02 09:55AM
  Re: Poke it with a wire ?Re: wrybread wrybread 05/11/02 10:11AM
  Re: Poke it with a wire ?Re: david f martin david f martin 05/11/02 12:45PM
  Re: Poke it with a wire ?Re: Fred Fred 05/11/02 02:04PM
  Re: unclogging the exhaust....Re: david f martin david f martin 05/11/02 03:16PM
  Mangled it ?Re: Fred Fred 05/12/02 06:42PM
  freds advice site?Re: Ben Phillips Ben Phillips 05/12/02 11:38PM
  Re: freds advice site?Re: don-ohio don-ohio 05/12/02 11:39PM
  Re: freds advice site?Re: don-ohio don-ohio 05/12/02 11:42PM
  Re: freds advice site?Re: ben ben 05/15/02 12:18AM
  Re: freds advice site?Re: Fred Fred 05/15/02 12:54AM
  Re: Poke it with a wire ?Re: jim jim 05/12/02 05:07PM
  Re: Mangled it ?Re: david f martin david f martin 05/12/02 07:10PM
  Re: Hurt toesRe: Wayne Wayne 05/13/02 10:33AM
  Re: Mangled it ?Re: Chris Rice Chris Rice 05/13/02 10:53AM
  Re: Mangled it ?Re: david f martin david f martin 05/13/02 08:52PM
  Re: Mangled it ?Re: Wayne Wayne 05/13/02 10:29PM
  Re: Mangled it ?Re: david f martin david f martin 05/14/02 12:06AM
  David, VW QuestionRe: Ron Brown Ron Brown 05/14/02 11:46AM
  Re: David, VW QuestionRe: david f martin david f martin 05/14/02 08:20PM
  Re: David, VW QuestionRe: Ron Brown Ron Brown 05/16/02 01:36AM
