RE: Motobecane leaking gasoline
Shane J. Wolfe /
I would check out the float needle and float. I just repaired my carb by replacing those parts. It was basically leaking like yours, and then I pulled it apart one day, killing the gasket in the process. It sprayed gas out. I replaced the gaskets in the carb, along with the previously mentioned parts, and it works fine. Took all of about 5 minutes on my 78 Puch Maxi.
  Motobecane leaking gasolineTopic by: Gerah Gerah 10/02/00 10:13PM
  RE: Motobecane leaking gasolineRe: Ivo Ivo 10/03/00 06:16PM
  RE: Motobecane leaking gasolineRe: moby moby 10/03/00 08:54PM
  RE: Motobecane leaking gasolineRe: Shane J. Wolfe Shane J. Wolfe 10/03/00 09:07PM
  RE: Motobecane leaking gasolineRe: Rob Rob 10/14/00 05:29PM
