Re: I lost my key and now I'm a monkey
Ron Brown /
If it is a woodruff (semi-circular) key, you need the diameter too. Try to find a coin or something similar that you can fit into the rounded slot in the shaft, then mark it at about the depth of the flywheel groove. This will give you a good place to start.
Ron
