Re: I'm an idiot for not tightening the flywheel
mbartell /
ummmmmm
There should be a key on that shaft. The nut will hold it in place, but it will still rotate if you don't have the key there. The flywheel has to go on ONLY ONE WAY.
The key is a peice of hardeded steel that goes in a slot or hole on your crankshaft. There should be a slot machined on your flywheel's center hole, to slide over this key.
