Re: 55 miles... take that don-oh !
Jimmy /
Ron Brown wrote:
> Jimmy,
> Provided your jetting is not too lean, screaming (wide open
> throttle) down hill should not be a problem.
> 2 strokes do have a generic problem in that if you close the
> throttle at high rpm, the internal parts are still moving
> fast but the lubrication is minimal because it is
> proportional to throttle opening. Add to this, the fact that
> the cooling fins are getting lots of air flow to cool off and
> shrink the cylinder, while the hot piston gets no significand
> cooling and you have a recipe for disaster.
> If you watch 2 stroke road racing, more often than not, these
> bikes will sieze when the throttle is closed at high speed,
> such as the entry to a corner.
> As for running a ped in 15 minute stretches then cooling
> off. Are you sure this is not just for the running in
> period? I have never heard this rule applied to a broken-in
> engine.
> Ron
Hi Ron
You make very good points there,I think you are correct on all accounts ..... I am convinced that my stock Avanti Pacco carb had a marginal sized 52 jet in it when I bought the bike... and that the famed back wheel lockups mostly occur as people come down hills, turning down their throttles,creating heat and soft-siezes... I think Avanti owners should put alittle larger jets in their carbs then the stock ones.. They advertise the bikes for their gas mileage, which is most important to Indian customers due to their econmy and high gas prices, but the engines can overheat.
I'm at work and don't have the manual with me... I'm pretty sure that they said to run 15 miles and let it cool for nornal running, and didn't mean the break in period...but who knows ? The manual isn't too well written...also, maybe they know their jets are small , making the engines run hot , and suggest short hop travelling ? I'll check the manual when at home.
  55 miles... take that don-oh !Topic by: Fred Fred 05/04/02 06:37PM
  Re: 55 miles... take that don-oh !Re: Dave Gregory Dave Gregory 05/04/02 08:02PM
  My odometer IS in miles... not kmRe: Fred Fred 05/04/02 08:30PM
  Re: My odometer IS in miles... not kmRe: wonko wonko 05/05/02 02:37AM
  Re: My odometer IS in miles... not kmRe: Ron Brown Ron Brown 05/05/02 12:23PM
  Re: My odometer IS in miles... not kmRe: Fred Fred 05/05/02 03:27PM
  Re: My odometer IS in miles... not kmRe: Ron Brown Ron Brown 05/05/02 03:47PM
  140 milesRe: Fred Fred 05/05/02 07:50PM
  Re: 140 milesRe: Casey B Casey B 05/05/02 11:02PM
  PA50 pipeRe: Fred Fred 05/06/02 09:02PM
  Re: PA50 pipeRe: Casey B Casey B 05/06/02 09:10PM
  Re: 140 milesRe: Ron Brown Ron Brown 05/06/02 11:11AM
  Re: My odometer IS in miles... not kmRe: Dave Gregory Dave Gregory 05/05/02 09:32PM
  Re: My odometer IS in miles... not kmRe: Ron Brown Ron Brown 05/06/02 10:21AM
  Re: 55 miles... take that don-oh !Re: Chris S Chris S 05/05/02 10:14AM
  Re: 55 miles... take that don-oh !Re: Dave Gregory Dave Gregory 05/05/02 03:08PM
  Re: 55 miles... take that don-oh !Re: Fred Fred 05/05/02 03:37PM
  Re: 55 miles... take that don-oh !Re: Jimmy Jimmy 05/06/02 02:13PM
  Re: 55 miles... take that don-oh !Re: Ron Brown Ron Brown 05/06/02 02:54PM
  Re: 55 miles... take that don-oh !Re: Jimmy Jimmy 05/07/02 02:14PM
  Re: 55 miles... take that don-oh !Re: Ron Brown Ron Brown 05/07/02 02:54PM
  Re: 55 miles... take that don-oh !Re: Jimmy Jimmy 05/08/02 08:46AM
  Re: 55 miles... take that don-oh !Re: Jimmy Jimmy 05/08/02 09:01AM
  filterRe: Phil Phil 05/06/02 10:32AM
  Re: 550 miles...had a BLAST ! !Re: don-ohio don-ohio 05/10/02 04:30AM
