Fred,
Obviously, my sometimers is kicking in again, I thought you made the comment on k vs m, oh well.
I'm not ambitious enough to do a search, so lets bame someone else. It was most likely Don-Ohio who said it. : )
When I ride to the BBQ, I usually leave from M52 and I96, that makes it about 95 miles one way so if you cruise at 25 it is only 4 hours in the saddle.
Think about it.
Btw, Have you ever tried clearing your main jet on the road using the "suck it out" method? Rev the ped, block the air intake and twist the throttle wide open. Causes max flow through the main jet and will clear anything small enough to pass through it.
Ron
