"I have a moped that isn't starting, it has spark, gas, and oil. It is almost starting but then it just stops. I don't know a lot about the engine so any help would be appreciated. Just e-mail me."
"have you tried cleaning the air filter, the carbuerator, or the exhaust?<p><br>: I have a moped that isn't starting, it has spark, gas, and oil. It is almost starting but then it just stops. I don't know a lot about the engine so any help would be appreciated. Just e-mail me.<p>"
Check and see on the carb if the mixture screw is turned in or all the way out. This screw should be set at 1 1/2 turns from closed position.
": have you tried cleaning the air filter, the carbuerator, or the exhaust?<p>: <br>: : I have a moped that isn't starting, it has spark, gas, and oil. It is almost starting but then it just stops. I don't know a lot about the engine so any help would be appreciated. Just e-mail me.<p> yeah try getting a new spark plug <br> if this does not work then try<br> fresh gas then if thats no hope <br> then try checking the head gasket <br> because this has happened to me once."
Do you have your choke on?<br>
