One more suggestion (suggested to me when I asked the same question):
It was mentioned that I should somehow cover the inlet brass nipple on the intake manifold so that it's not sucking in extra air. THe extra air could make the engine run too hot. I'm actually still using the pump, but I do get nervous wondering if it's working properly. It's not like you can see the oil-level decreasing in the oiltank. Good luck.
