You should flush it out some with kerosene and oil mixed first,Aaron. That milky look is water absorbed into the oil usually,and is big trouble. Do a 5 minute flush if you can. If the fill plug is down on the side of the case,it's probably a level-indicator too.But if you'd just post the Make and model of moped,we'd give you an exact answer.
