Thanks Fred!
Terry Smith /
Thanks, Fred for the advice on timing my Tomos A3 engine. I use a variation of your method. Instead of the coat hanger, I made a mark on the engine housing at TDC and a mark on the flywheel at TDC. I then measured and made the F mark at 3/4 inch as you suggested. Then, I used an ohm meter to set the points to open at the F mark. I did this so I would not have to start the engine every time to check it with the timing light. After I set it with the meter, I did start it and the timing light showed the timing to be correct. You're a genius!
Your help is greatly appreciated as it is much more fun to ride the bike now with it running correctly. If you ever come to Texas, I 'll buy you a cold one.
Thanks,
Terry Smith
Re: Thanks Fred!
You can't beat our Guru Fred, Terry. He's an engine genius all right!. (:^)
Re: Thanks Fred!
Hardly a genius... but I have been playing with engines for years.
Check this out.... I found out yesterday that one of the guys I have worked with a few times on motorcycle club events has a masters degree in Physics.
Glad it worked for you Terry.
So it ran pretty good ?
And... did you measure the diameter of your flywheel ?
(that 3/4" number was for the 4.5" flywheel on the Tomos I have here right now)
Re: Thanks Fred!
Terry Smith /
It runs much, much better. The flywheel measured 4.5 in, so I went with it. I just got back from riding and it was great. Thanks again!
I've got two friends that just got new scooters. If I find enough people, maybe I'll get a group together here.
Terry
