RE: Getting close to winter.
Ivo /
And put some oil in the cylinder through the sparkplughole and disconnect the battery (if you have one).
Covering up your ped with plastic will cause accelerated rust, but without the plastic it may rust too, so spray a lot of 10W40 all over the bike before you cover it up. You'll need to do some cleaning next spring but your ped wont be rusted.
If you're putting away a ped for a longer period of time (a couple of years) then you should fill up the gastank, carburettor and cylinder with oil.
  Getting close to winter.Topic by: scott scott 09/30/00 09:44AM
  RE: Getting close to winter.Re: DOUG D DOUG D 09/30/00 11:21AM
  RE: Getting close to winter.Re: Ivo Ivo 09/30/00 12:53PM
  Drain the floatbowl.Re: Fred Fred 09/30/00 10:53PM
  RE: Getting close to winter.Re: Jim C. Jim C. 10/01/00 12:26AM
  RE: Getting close to winter.Re: Reeperette Reeperette 10/02/00 08:26AM
  Semi-CorrectionRe: Reeperette Reeperette 10/03/00 01:04AM
  RE: Getting close to winter.Re: Tom Tom 10/09/00 08:56AM
