RE: Getting close to winter.
DOUG D /
Your right, don`t want the gaskets to dry up or the tank to rust. If you add some GAS STABILIZER to it you should be good to go, run it to get it in carb and in spring, you don`t need to but I would drain and fill with fresh gas mix, also running a little carb cleaner like "SEA FOAM" in spring would be good too. DOUG D in VA.
  Getting close to winter.Topic by: scott scott 09/30/00 09:44AM
  RE: Getting close to winter.Re: DOUG D DOUG D 09/30/00 11:21AM
  RE: Getting close to winter.Re: Ivo Ivo 09/30/00 12:53PM
  Drain the floatbowl.Re: Fred Fred 09/30/00 10:53PM
  RE: Getting close to winter.Re: Jim C. Jim C. 10/01/00 12:26AM
  RE: Getting close to winter.Re: Reeperette Reeperette 10/02/00 08:26AM
  Semi-CorrectionRe: Reeperette Reeperette 10/03/00 01:04AM
  RE: Getting close to winter.Re: Tom Tom 10/09/00 08:56AM
