Re: im going to try it
Ron Brown /
Duck,
More power to you if you want to play, but here are a couple of thoughts for you.
You mention that when you brake a car, the brakes get hot. With dynamic braking, the alternator is used to slow the wheels instead of the brakes. The energy of the rolling car is converted by the alternator into battery charging current. Does this sound like alternators don't require any power to turn them.
Have you ever jump started a car? If you have the engine idling on the donor car when you hook up the battery cable, you can hear the donor car's engine "grunt" when you hook up the dead battery. The alternator is applying this load to the engine as it tries to charge the dead battery. Does this sound like alternators don't require any power to turn them.
Motorcycle racers remove the magneto/alternator from thier bikes and switch to a "total loss" battery powered igniyion system, just to eliminate the drag of the alternator and get a little more speed.
I am sure you will be able to rationalize this and go ahead with your project so good luck to you.
Ron
  off topic.. but...Topic by: duck duck 05/02/02 12:18AM
  Re: off topic.. but...Re: Brandon Eliason Brandon Eliason 05/02/02 12:34AM
  Re: off topic.. but...Re: Chucky D Chucky D 05/02/02 12:56AM
  Re: off topic.. but...Re: Richard Richard 05/02/02 01:07AM
  Re: off topic.. but...Re: Ron Brown Ron Brown 05/02/02 11:19AM
  Re: off topic.. but...Re: duck duck 05/02/02 04:29PM
  we can do anything, if we had the $$Re: InfectedBootSector InfectedBootSector 05/02/02 05:46PM
  Re: off topic.. but...Re: Spike Bachman Spike Bachman 05/02/02 04:57PM
  Re: off topic.. but...Re: duck duck 05/02/02 05:40PM
  Re: off topic.. but...Re: duck duck 05/02/02 05:42PM
  Re: off topic.. but...Re: Jeremy Hay-Draude Jeremy Hay-Draude 05/03/02 09:25PM
  Re: off topic.. but...Re: Andy Andy 05/02/02 05:49PM
  Re: off topic.. but...Re: don-ohio don-ohio 05/02/02 06:11PM
  On topic..,Question, Ideas.Re: Wayne Wayne 05/02/02 06:43PM
  Re: On topic..,Question, Ideas.Re: don-ohio don-ohio 05/02/02 06:59PM
  Patent office (On topic) Free EnergyRe: Wayne Wayne 05/02/02 07:00PM
  Re: off topic.. but...Re: duck duck 05/02/02 06:12PM
  im going to try itRe: duck duck 05/02/02 06:23PM
  Re: im going to try itRe: Ron Brown Ron Brown 05/03/02 10:52AM
  Re: off topic.. but...Re: Chucky D Chucky D 05/04/02 04:29PM
  Re: off topic.. but...Re: Wayne Wayne 05/04/02 04:54PM
  ronRe: duck duck 05/04/02 09:49PM
  Re: ronRe: Ron Brown Ron Brown 05/05/02 11:43AM
