Re: off topic.. but...
Chucky D /
Well, it’s a good idea except for something my father said once, "You can't make what you don’t have". A windmill system that you described could partially charge the battery as you drive, but you will always lose more power than you gain. Basically, what you are describing a perpetual motion type machine, one that once started could conceivably continue to run forever, this is impossibility. I once actually had a very similar idea; I took a high powered electric remote control car and attached a fairly efficient windmill type generator to the top. It did indeed extend battery life somewhat, but not by much and it certainly could never fully charge the battery.
Even IF it was a windy day thus adding to the power created by the wind created by the car, you will still never achieve the desired results. This is because you lose power when you make the conversion of "wind" energy to electrical power, through the wiring that connects the windmill to the battery, and the battery itself as it sits.
It actually is a good idea to add a windmill type generator to the car, so that while in motion, the windmill could assist the plug, motor, or whatever other device is charging the battery, thus extending battery life.
That’s all, Chucky D
  off topic.. but...Topic by: duck duck 05/02/02 12:18AM
  Re: off topic.. but...Re: Brandon Eliason Brandon Eliason 05/02/02 12:34AM
  Re: off topic.. but...Re: Chucky D Chucky D 05/02/02 12:56AM
  Re: off topic.. but...Re: Richard Richard 05/02/02 01:07AM
  Re: off topic.. but...Re: Ron Brown Ron Brown 05/02/02 11:19AM
  Re: off topic.. but...Re: duck duck 05/02/02 04:29PM
  we can do anything, if we had the $$Re: InfectedBootSector InfectedBootSector 05/02/02 05:46PM
  Re: off topic.. but...Re: Spike Bachman Spike Bachman 05/02/02 04:57PM
  Re: off topic.. but...Re: duck duck 05/02/02 05:40PM
  Re: off topic.. but...Re: duck duck 05/02/02 05:42PM
  Re: off topic.. but...Re: Jeremy Hay-Draude Jeremy Hay-Draude 05/03/02 09:25PM
  Re: off topic.. but...Re: Andy Andy 05/02/02 05:49PM
  Re: off topic.. but...Re: don-ohio don-ohio 05/02/02 06:11PM
  On topic..,Question, Ideas.Re: Wayne Wayne 05/02/02 06:43PM
  Re: On topic..,Question, Ideas.Re: don-ohio don-ohio 05/02/02 06:59PM
  Patent office (On topic) Free EnergyRe: Wayne Wayne 05/02/02 07:00PM
  Re: off topic.. but...Re: duck duck 05/02/02 06:12PM
  im going to try itRe: duck duck 05/02/02 06:23PM
  Re: im going to try itRe: Ron Brown Ron Brown 05/03/02 10:52AM
  Re: off topic.. but...Re: Chucky D Chucky D 05/04/02 04:29PM
  Re: off topic.. but...Re: Wayne Wayne 05/04/02 04:54PM
  ronRe: duck duck 05/04/02 09:49PM
  Re: ronRe: Ron Brown Ron Brown 05/05/02 11:43AM
