Honda PA-50 belt width ... what is it ?
Belt drive variators are dependant on the width of the belt for proper functioning.
I tried to find this out twice so far... and can't find what the correct width is supposed to be.
It would be in a service manual... but I don't have one.
So can anybody with a PA-50 measure their belt width for me and let me know how wide their belt is ?? (and how many miles the Odo shows ?)
or if you have a service manual... it would be great if you could look it up for me... (78 PA-50I)... PA50II is probably the same ??
(just lay a tape measure or ruler or scale across it and lean over and try to read an accurate measurement)
Many snowmobiles have a 'width diagram' sticker under their hood... so you juat take the belt and lay it on the diagram and see if it is 'under width'... then you need a new belt.
A belt worn too narrow takes speed off the top end.
Re: Honda PA-50 belt width ... what is it ?
yo fred.. i have a pa50II (and a manual!)... ill go find out for you. hold tight.. just have to see if i have a ruler... )
do you need a copy of the manual?
casey
I don't need the manual (or copies).. as long as you tell me what it says is the minimum belt width... (width of a new one would be nice too)
(do you have a service manual or owners manual ??)
And if you could measure YOUR belt width it would be nice too.
hey fred.. i have the service manual... like 150 pages.. but i cant find the spec for the belt width anywhere.. ill look more when i get home from work.
also, walker has been borrowing my pa50, so i will have to go to his house to measure it. i remembered that as i went down to the basement this morning to measure for you... ill figure it out.
casey
OK... no biggie... get it when you can.
I am wondering if we can still get these belts... I hope so.
cool... ill check as soon as i get to my honda... i do know my odometer only shows like 950 miles... and my speedo cable just broke a couple months ago... so whatever mine says should be fairly accurate...
have you tried ordering one from Honda? i have gotten lots of parts for mine from them... they special order them, but you can get almost any part.. for an '82, anyways.. which i imagine most parts would work for yours... i just get the part #'s from <a href="http://www.partsfish.com">www.partsfish.com</a> and call them with the #'s.
casey
