Re: Up jet it and open the airbox.
Ron Brown /
Matt,
You are correct about 4 stroking being caused by a rich mixture, however, several things can cause this, only one of which is the main jet.
If the air filter/airbox is restrictive, then the faster you go, the more air the engine demands and the lower the pressure in the intake causing a rich mixture.
Sometimes, when you remove this restriction, the mixture will lean out at lower rpm and you have to go up a jet size or two.
Another common problem is, for want of a better name, "double dipping". At higher rpm, the intake airstream will reverse direction as the intake port closes, this causes the air, which has picked up gas while going forward, to pick up more gas from the carb as it travels backward and then still more as it goes forward again into the engine.
If you reduce the main jet size to cure this one, then you are in danger of severely leaning out the mixture at lower RPM, such as going up hill at full throttle. The result being an overheated engine recieving a minimum amount of lube.
This is why plug chops under different conditions are so important.
Ron
  Look at this "Classic" (pic)Topic by: Ike Ike 05/01/02 12:19PM
  Re: Look at this "Classic" (pic)Re: don-ohio don-ohio 05/01/02 12:27PM
  Re: Look at this "Classic" (pic)Re: Ike Ike 05/01/02 01:26PM
  Re: Look at this "Classic" (pic)Re: don-ohio don-ohio 05/01/02 01:56PM
  Re: Look at this "Classic" (pic)Re: Dan Dan 05/01/02 12:34PM
  Re: Look at this "Classic" (pic)Re: kevin kevin 05/01/02 12:46PM
  Re: Look at this "Classic" (pic)Re: don-ohio don-ohio 05/01/02 12:53PM
  Re:DonRe: kevin kevin 05/01/02 01:25PM
  Yeah,Kevin!Re: don-ohio don-ohio 05/01/02 01:54PM
  Re: Look at this "Classic" (pic)Re: Ike Ike 05/01/02 12:52PM
  Still ridin' the Targa,Ike?Re: don-ohio don-ohio 05/01/02 12:55PM
  Re: Still ridin' the Targa,Ike?Re: Ike Ike 05/01/02 01:22PM
  Up jet it and open the airbox.Re: don-ohio don-ohio 05/01/02 01:51PM
  Re: Up jet it and open the airbox.Re: Ike Ike 05/01/02 02:38PM
  Re: Up jet it and open the airbox.Re: don-ohio don-ohio 05/01/02 03:29PM
  Just Yank it.Re: Reeperette Reeperette 05/02/02 11:40AM
  Re: Still ridin' the Targa,Ike?Re: Ron Brown Ron Brown 05/01/02 02:27PM
  Re: Up jet it and open the airbox.Re: Matt Wilson Matt Wilson 05/01/02 08:21PM
  Re: Up jet it and open the airbox.Re: Ron Brown Ron Brown 05/02/02 10:41AM
  Re: Look at this "Classic" (pic)Re: Jon Dalton Jon Dalton 05/03/02 11:08AM
  Re: Look at this "Classic" (pic)Re: Chris Robertson Chris Robertson 05/19/02 11:49PM
  Re: Look at this "Classic" (pic)Re: Ike Ike 05/20/02 02:12AM
