No spark on Puch
Team Angel III /
Hi All!
I bought a Puch moped to build for my son. I got a lot of good advice here this weekend! Thank you all! I had a problem of getting no spark. I tried a new spark plug, but that did not help. Where would be a good place to start diagnosing this problem? Cheers!
George
Re: No spark on Puch
Luke “Funkenet” Hosfield /
The moped repair forum would be an excellent place to start.
One Chris G 📉⚰️ /
did you check the kill switch?
you basturd you better sell me this bike
ground the blue/black wire
Josh Rampulla /
do this
http://www.mopedarmy.com/wiki/Hardwiring_a_Puch
its very simple, if still no spark its a bigger issue, but i'm guessing its a grounding issue somewhere or something small like that
Team Angel III /
How do I check the kill switch? If I was to hardwire the moped, will that take away from the value of it?
Please use the wiki first. Then you can post on the repair forum.
buy a points file for the auto store its about 1.99 and open up the left cover if your sitting on the bike. This is the first cheap step.
i had same trouble, dodgy ground wire on rear light, cleaned it and got big blue spark immediatly, strange but true
Elliot Craig /
Make sure the horn is grounded and make sure everything else is, could be the points, the ignition coil, a faulty ground, etc. a Puch wont start unless the horn is grounded I believe.
Probably Fred /
Me thinks fake poster
