Re: 11th Annual MopedLar Ride....May 25th, NJ
Moped Lar (OFMC) /
To all ride Attendees......please use the next week to get your moped into riding "shape". The ride is 63 miles long and can take it's toll on bikes that are not well maintained. We usually experience about a 10% breakdown rate each year and we'd like to reduce that percentage as much as possible. The four most common breakdown causes are:
Flat/blown tires......please replace bald and cracked tires before the ride.
Clogged fuel filters....please check and replace your inline fuel filter if needed. Make sure your gas tank is clean and free of scaly rust.
Clogged main carb jets.....If you don't have an inline filter, you may want to install one, especially if you have a rusty tank. Check your carb bowl for sediment and clean it out if needed.
Running out of gas....Please make sure you start the ride with a full tank of gas. There will be a gas stop at the mid-point of the ride. Please take advantage of this opportunity. Don't rely on the chase vehicle to bail you out if you run out of gas. There will be a very limited amount of emergency gas available.
Please also check your drive chains for proper tension and lubrication.
Thanks and have a safe ride to NJ!!! (edited)
  11th Annual MopedLar Ride....May 25th, NJTopic by: Moped Lar (OFMC) Moped Lar (OFMC) 02/18/13 01:49PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Monti S Monti S 02/18/13 01:53PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Travis Tutorial Travis Tutorial 02/18/13 02:36PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 02/18/13 03:37PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 02/19/13 07:34AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 02/19/13 07:45AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: All Gas No Brakes All Gas No Brakes 02/19/13 09:58AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: BERGS . BERGS . 02/19/13 04:02PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: paul massey paul massey 02/19/13 05:08PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Josh Rampulla Josh Rampulla 02/19/13 05:13PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Lauri V Lauri V 02/19/13 06:34PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 02/19/13 09:05PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Robert Kielblock Robert Kielblock 03/02/13 09:17PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Robert Kielblock Robert Kielblock 03/02/13 09:53PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 02/20/13 07:40AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Larry Picarello Larry Picarello 02/20/13 08:19AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 02/20/13 08:36AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: paul goddard paul goddard 04/03/13 02:27PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Arnie Sparaco Arnie Sparaco 02/28/13 01:00AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 02/28/13 07:39AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 02/28/13 07:43AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Tal Reznikov Tal Reznikov 02/28/13 10:32PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Beard Road Bruiser (SoB) Beard Road Bruiser (SoB) 03/01/13 12:37PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Korey Dubyah Korey Dubyah 03/01/13 12:57PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: The Reverend Defecator The Reverend Defecator 03/02/13 05:47PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 03/02/13 08:30PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Chris Driscoll Chris Driscoll 03/10/13 11:48AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 03/10/13 12:13PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: BERGS . BERGS . 03/10/13 05:32PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 03/19/13 05:49PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 03/20/13 07:23AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 03/20/13 07:35AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Ian T Ian T 03/20/13 06:56PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 03/20/13 07:52PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: paul massey paul massey 03/20/13 10:06PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Beard Road Bruiser (SoB) Beard Road Bruiser (SoB) 03/21/13 09:44AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 03/21/13 11:54AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: paul massey paul massey 03/21/13 06:20PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: LGN Danny LGN Danny 03/21/13 12:50PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 03/21/13 08:05PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: roy raider roy raider 03/22/13 05:45PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 03/22/13 06:03PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: The Reverend Defecator The Reverend Defecator 04/02/13 05:47PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Wolf Wizard Wolf Wizard 04/02/13 06:16PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/03/13 02:23AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/03/13 06:57AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 04/03/13 07:39AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 04/03/13 08:07PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: John Joedicke John Joedicke 04/04/13 06:41AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/04/13 07:13AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 04/10/13 12:43PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Arnie Sparaco Arnie Sparaco 04/12/13 05:42PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Pushrod Fifty Pushrod Fifty 04/12/13 10:37PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/13/13 09:14AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Nate Dood Nate Dood 04/17/13 01:24PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Tal Reznikov Tal Reznikov 04/17/13 01:49PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: John Joedicke John Joedicke 04/18/13 05:53AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Button Rojo Button Rojo 04/18/13 12:48PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/18/13 12:59PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/20/13 07:58AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Mick Baltards Mick Baltards 04/20/13 10:27AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/20/13 12:35PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/20/13 11:47AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/20/13 01:03PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Lauri V Lauri V 04/20/13 08:16PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/21/13 12:30PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Jerry Franek Jerry Franek 04/21/13 01:02PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 04/21/13 11:08PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Jerry Franek Jerry Franek 04/22/13 12:30PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/22/13 02:58PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/22/13 12:37PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moe Lavoie Moe Lavoie 04/22/13 06:53PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Arnie Sparaco Arnie Sparaco 04/22/13 01:18PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/22/13 01:23PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Jerry Franek Jerry Franek 04/22/13 02:53PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 04/22/13 08:12PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/22/13 08:27PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Arnie Sparaco Arnie Sparaco 04/22/13 08:31PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/22/13 08:40PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/23/13 01:18PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Arnie Sparaco Arnie Sparaco 04/23/13 01:58PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/23/13 02:01PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Arnie Sparaco Arnie Sparaco 04/23/13 02:14PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/23/13 02:16PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 04/23/13 04:12PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Patrick Kearns Patrick Kearns 04/23/13 05:27PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Raymond Wright IV Raymond Wright IV 04/25/13 08:58AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/25/13 01:03PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 04/28/13 10:41AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Aqua Dublavee Aqua Dublavee 05/05/13 05:46PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/06/13 07:38AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Ian T Ian T 05/06/13 04:36PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Lauri V Lauri V 05/06/13 07:32PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/07/13 06:45AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: John Joedicke John Joedicke 05/07/13 07:46AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Matt Wagner Matt Wagner 05/07/13 07:23AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Jason Collier Jason Collier 05/07/13 11:11PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/08/13 01:32PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Nick Edelschein Nick Edelschein 05/08/13 09:40PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Beard Road Bruiser (SoB) Beard Road Bruiser (SoB) 05/08/13 10:24PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/10/13 12:56PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Nick Edelschein Nick Edelschein 05/14/13 01:31PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: ♣Slew Foot♣ ♣Slew Foot♣ 05/14/13 02:50PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/14/13 02:29PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/16/13 08:09AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Wolf Wizard Wolf Wizard 05/16/13 08:24AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 05/16/13 09:54AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/16/13 10:31AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Jerry Franek Jerry Franek 05/16/13 03:38PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 05/16/13 09:57PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Wolf Wizard Wolf Wizard 05/17/13 01:41AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Beard Road Bruiser (SoB) Beard Road Bruiser (SoB) 05/19/13 10:56PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/17/13 06:51AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: GET REALIZED! BE HERE NOW! GET REALIZED! BE HERE NOW! 05/17/13 09:03AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/18/13 10:26AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Jerry Franek Jerry Franek 05/19/13 09:57AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moe Lavoie Moe Lavoie 05/19/13 10:20AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/19/13 10:08AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/19/13 12:47PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: ♣Slew Foot♣ ♣Slew Foot♣ 05/19/13 06:24PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 05/19/13 01:47PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Wolf Wizard Wolf Wizard 05/20/13 08:26AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/20/13 08:49AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: joϟh hoϟier joϟh hoϟier 05/20/13 09:37AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/20/13 11:02AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Jerry Franek Jerry Franek 05/20/13 11:47AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Sir Christopher BLKBLK Sir Christopher BLKBLK 05/20/13 12:02PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/20/13 02:17PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 05/20/13 02:48PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Raymond Wright IV Raymond Wright IV 05/20/13 03:47PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/20/13 03:58PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Harvey Bower Harvey Bower 05/20/13 04:05PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/20/13 04:08PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 05/20/13 09:20PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Lis Pony Lis Pony 05/20/13 09:31PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: GET REALIZED! BE HERE NOW! GET REALIZED! BE HERE NOW! 05/20/13 10:51PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Monti S Monti S 05/20/13 11:33PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Perfekt Timing Angel Perfekt Timing Angel 05/21/13 12:06AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Ian T Ian T 05/21/13 07:29AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/21/13 06:27AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/21/13 06:49AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Jeff Mccarthy Jeff Mccarthy 05/21/13 07:13AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: ♣Slew Foot♣ ♣Slew Foot♣ 05/21/13 09:49AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: john cervini john cervini 05/21/13 07:14AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Perfekt Timing Angel Perfekt Timing Angel 05/21/13 10:11AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Perfekt Timing Angel Perfekt Timing Angel 05/21/13 10:13AM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/21/13 12:34PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Jeff Mccarthy Jeff Mccarthy 05/21/13 03:41PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 05/21/13 09:38PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Sir Christopher BLKBLK Sir Christopher BLKBLK 05/21/13 09:55PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Fish ook Fish ook 05/21/13 10:27PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Wolf Wizard Wolf Wizard 05/22/13 09:35PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Nate Dood Nate Dood 05/22/13 10:25PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Jason Bermudez Jason Bermudez 05/23/13 04:40PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: GET REALIZED! BE HERE NOW! GET REALIZED! BE HERE NOW! 05/23/13 04:56PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 05/23/13 08:56PM
  Re: 11th Annual MopedLar Ride....May 25th, NJRe: Rob K Rob K 05/23/13 08:57PM
