REPOST (initial Faq draft)
Reeperette /
Someone suggested a Tomos Faq...so, here's a prelim, trying to keep to stuff you don't find in the manuals.
Basic Tomos Faq.
Engine Classes, A3 and A5(A35).
Both 50cc, both 38mm x 43mm stroke.
Best to refer to as "A3" or "A5" instead of "A35" to avoid parts confusion.
Transmission fliud - 220cc's (220ml) of Dexron type III is reccommended, but 10w30/10w40 motor oil can also be used.
The transmission casing screws are 4.2mm hex, good LUCK finding a hexkey that fits, a 4mm will do in a pinch, just don't strip them out.
Cylinder bolts are 11mm and require a deepsocket.
Be very careful tightening these, they are easy to strip and if that happens, it's a real pain in the arse to fix.
Exhaust bolts are 10mm and one of them is very difficult to get a socket onto, unless you have an angle-socket kit.
Removing the baffle prevents crud backup, adds a negligable performance increase and more aggressive exhaust note.
Carberator is either an Encawri (Old Bullet models) or a DelLorto 14/12, usually with a #51 main jet.
Compression ratio should be 9.1:1 (about 9/1)
Electrical output should be 12v/50W (some older models) or 12v/80W.
Brown wires are ground, black or yellow should be hot leads.
Plug gap should be 0.5mm
Reccommended plugs
Champion = L82C/L86C/L90C (Depends on which book you check)
Bosch = W8AC
NGK = B5HS
Motorcraft = AE4/AE4x/AE6 (depends on book)
Denso = W16-FSU
AC Delco = 422Z
Splitfire = SF409C
Stock tires suck, Cheng Shin (imported via maxxis tire and rubber) makes very good replacement tires that fit well.
BELL self-sealing tubes, 1"-2" oversize, fit Tomos tires and work quite well. (available at walmart)
Chainsaw lube works best on the Tomos drive chain.
The tires are 16" by 2.125", mags or spokes, an ordinary bicycle spoke wrench/tool fits the spokes.
A pair of heavy tire spoons not only come in handy for changing tires, they are also helpful in removing the flywheel.
The A3 and A5 left side transmission covers are interchangeable.
  Need Manual for 2000 Tomos Targa LXTopic by: Dr Alan Lipman Dr Alan Lipman 04/24/02 08:13AM
  Next Best thing.Re: Reeperette Reeperette 04/24/02 10:11AM
  Re: Next Best thing.Re: Dr Alan Lipman Dr Alan Lipman 04/24/02 10:16AM
  Nah, Don't apologise...Re: Reeperette Reeperette 04/24/02 12:15PM
  REPOST (Instructions)Re: Reeperette Reeperette 04/24/02 12:19PM
  REPOST (Spark Plugs)Re: Reeperette Reeperette 04/24/02 12:25PM
  REPOST (Sprocket Change)Re: Reeperette Reeperette 04/24/02 12:51PM
  REPOST (Sprocket Change)Re: Wayne Wayne 04/24/02 02:42PM
  There is.Re: Reeperette Reeperette 04/24/02 10:38PM
  Re: There is (Front Sprocket)Re: Wayne Wayne 04/24/02 10:44PM
  Re: There is (Front Sprocket)Re: don-ohio don-ohio 04/24/02 10:45PM
  Don&Wayne...Re: Reeperette Reeperette 04/24/02 10:53PM
  Re: Don&Wayne...Re: don-ohio don-ohio 04/24/02 10:55PM
  REPOST (Tire Chains)Re: Reeperette Reeperette 04/24/02 01:24PM
  REPOST (Tires&Tubes)Re: Reeperette Reeperette 04/24/02 01:32PM
  Not at Jackson,OH yetRe: don-ohio don-ohio 04/24/02 09:53PM
  Re: Not at Jackson,OH yetRe: Wayne Wayne 04/24/02 10:22PM
  Re: Not at Jackson,OH yetRe: don-ohio don-ohio 04/24/02 10:25PM
  Me, Being a wise ass...Re: Wayne Wayne 04/24/02 10:34PM
  You're incorrigible,Wayne!LOL!!Re: don-ohio don-ohio 04/24/02 10:42PM
  REPOST (initial Faq draft)Re: Reeperette Reeperette 04/24/02 01:55PM
  Re: REPOST (initial Faq draft)Re: alan alan 04/28/02 07:29PM
  Re: REPOST (initial Faq draft)Re: Fred-Indiana Fred-Indiana 08/04/02 07:34PM
  Re: REPOST (initial Faq draft)Re: Reeperette Reeperette 08/05/02 01:35PM
  Re: Need Manual for 2000 Tomos Targa LXRe: me me 04/24/02 12:03PM
  Re: Need Manual for 2000 Tomos Targa LXRe: Wayne Wayne 04/24/02 01:57PM
